i was working with thee jetcore carrier board along with jetson orin nx 16gb module. But after flashing the display is not showing up and the monitor’s going to standby mode when the kit powered on. Any fix on this issue?
Some HDMI-only monitors may not display output due to differences in signal handling. Share us the make and model type of monitor. Also please check with a monitor with DP port.
Hi Pranav,
We also faced the same issue, but the problem was solved by vecros. They recommeded to use Monitors which has both hdmi and DP port in it. It worked. Try this
Hi SibySagar,
thanks for the mention. can you put list of monitors you tried and worked.
it will help others as well
I couldn’t find out the model as the label has been scratched out. But we have used DELL monitor
