Revolutionizing Drone Autonomy: Why JetCore-FC Leads the Pack in Integrated Flight Controllers
In the rapidly evolving world of drones and unmanned aerial vehicles (UAVs), the fusion of high-performance AI computing with robust flight control systems is no longer a luxury—it’s a necessity. Whether for industrial inspections, search and rescue, or autonomous mapping in GPS-denied environments, engineers and hobbyists alike demand boards that deliver seamless integration, reliability, and edge computing power. Enter the Jetcore FC from VECROS, a game-changing all-in-one flight controller board that’s setting new benchmarks. In this blog, we’ll dive into what makes Jetcore FC special and why it outshines competitors like the EchoPilot AI from EchoMAV, the Holybro Pixhawk Jetson Baseboard, and the ARK Jetson PAB Carrier.
What is Jetcore FC?
Developed by VECROS, an deeptech startup specializing in autonomous aerial robots, the Jetcore FC is an integrated platform that combines a NVIDIA Jetson carrier board with a Cube-compatible flight controller on a single PCB. This design eliminates the need for separate modules, reducing complexity, weight, and potential failure points in drone builds.
Key features include:
  • Compatibility: Supports NVIDIA Jetson modules such as Orin Nano, Orin NX, Xavier NX, and Nano, enabling AI tasks like computer vision, machine learning, and real-time object detection.
  • Dimensions and Weight: Ultra-compact at 136 × 66 × 16 mm and just 55 grams, making it ideal for lightweight drones where every gram counts.
  • Interfaces: Rich I/O options including Ethernet, UART, CAN, PWM for motor control, CSI for cameras, and more. It also features built-in sensor fusion for IMU (BMI088) and supports PWM, CAN, and UART for seamless communication with motors and sensors.
  • Power and Durability: 12V–24V input, operating temperature from -40°C to +85°C, and built-in crypto auth IC for security—perfect for harsh environments.
  • Autonomy Focus: Optimized for signal-denied and comms-denied operations, with VECROS’ battle-tested autonomy stack that powers their own drones for GPS-free navigation.
Jetcore FC isn’t just hardware; it’s born from years of real-world testing in high-risk scenarios, making it a reliable choice for developers pushing the boundaries of drone intelligence.
Head-to-Head: Jetcore FC vs. the Competition
The market for Jetson-integrated flight controllers is heating up, with several strong contenders. Let’s compare Jetcore FC to three popular alternatives based on key metrics like integration, size, weight, features, and overall value. (Note: All boards support PX4/ArduPilot and NVIDIA Jetson modules for AI workloads.)
Feature Jetcore FC (VECROS) EchoPilot AI (EchoMAV) Pixhawk Jetson Baseboard (Holybro) Jetson PAB Carrier (ARK)
Integration Single PCB combining Jetson carrier and Cube FC Core board with integrated FMU; optional carrier for I/O Baseboard with plug-in Pixhawk FC module Carrier with plug-in PAB FC module
Dimensions 136 × 66 × 16 mm 83 × 59 mm (core board) 126 × 80 × 38 mm 116 × 72 × 23 mm
Weight (base) 55g (without modules) Not specified 85g (without modules) 80g (without modules)
Power Input 12V–24V 7V-56V 7V–24V 5V (triple redundant)
Key Interfaces USB 3.0, Gigabit Ethernet, I2C, UART, CAN, PWM, MIPI CSI, NVMe SSD USB 3.0, Gigabit Ethernet, MIPI CSI, SPI, I2C, CAN, NVMe SSD, 4G/5G modem USB 3.0, Gigabit Ethernet, MIPI CSI, I2C, UART, CAN, NVMe SSD, Wi-Fi modem USB 3.0, Gigabit Ethernet, MIPI CSI, I2C, CAN, SPI, NVMe SSD, Wi-Fi modem
Origin Made in India USA-based General (China-based) USA-made
Unique Selling Point Ultra-compact all-in-one for autonomy in denied environments 4G/5G Modem support Ethernet Switch support Redundant power; high camera support
Price Range Affordable Premium Mid-range Premium
Vs. EchoPilot AI (EchoMAV)
EchoPilot AI is a powerhouse for professional applications. However, its modular approach (core board + optional carrier board) can add bulk and complexity compared to Jetcore’s true single-PCB integration. Jetcore edges out in compactness and weight, making it better for agile drones, while EchoPilot shines in connectivity-heavy missions.
Vs. Pixhawk Jetson Baseboard (Holybro)
Holybro’s board leverages the open-source Pixhawk Autopilot Bus for easy compatibility with various FC modules, offering solid I/O like dual Gigabit Ethernet and MIPI CSI. It’s versatile but larger and heavier (126 × 80 × 38 mm, 85g base), requiring plug-in FCs that increase assembly time. Jetcore’s fused design simplifies builds and reduces weight by about 35%, ideal for performance-critical applications without sacrificing AI capabilities.
Vs. Jetson PAB Carrier (ARK)
ARK’s offering is NDAA-compliant and USA-made, with triple redundant power inputs and quadruple MIPI CSI for advanced multi-camera setups—perfect for defense or high-reliability needs. That said, it’s not as compact (116 × 72 × 23 mm, 80g base) and relies on plug-in modules, potentially raising costs and complexity. Jetcore provides similar robustness in a smaller, lighter package, with a focus on autonomy that’s “battle-tested” in VECROS’ own drones.
Why Jetcore FC Comes Out on Top
Jetcore FC excels where it matters most for modern drone developers: true integration on a single PCB , which minimizes latency, wiring hassles, and failure risks. Its featherweight design (55g) outperforms heavier rivals, enabling longer flight times and better maneuvrability—crucial for swarms or endurance missions. While competitors like EchoPilot offer more peripherals (e.g., modems), Jetcore’s focus on core essentials keeps it affordable and streamlined without bloat.
Moreover, VECROS’ emphasis on GPS-denied autonomy, powered by onboard AI, gives it an edge in real-world scenarios like indoor navigation or jammed environments. Unlike modular boards that require custom stacking, Jetcore is plug-and-play ready, saving time for innovators. If you’re building for industrial edge computing or robotics, its wide temperature range and security features add unmatched reliability.
In a field where every ounce and millisecond counts, Jetcore FC isn’t just competitive—it’s optimized for the future of autonomous flight.
Final Thoughts
If you’re tired of searching separate carriers and controllers, the Jetcore FC offers an elegant, high-performance alternative that’s lighter, simpler, and ready for AI-driven challenges. Check it out on VECROS’ store or dive into their docs for tutorials. What are your thoughts on integrated boards? Drop a comment below—let’s discuss the next big thing in drone tech!
Written by Manas from VECROS Team @E_Motron
[1]Shop from : JETCORE-FC || Jetcore Flight Controller Board – vecros store
[2] Checkout Detailed Documentation: JETCORE FC | Vecros Docs
  1. 1 ↩︎
  2. Footnotes ↩︎
