JetCore support for Orin Nano with 5 RealSense D435iF and WiFi”
Hello,
I am working with a Jetson Orin Nano module and plan to use it with the JetCore carrier board. My setup includes five Intel RealSense D435iF cameras (USB 3.0) for SLAM + obstacle avoidance, and I also need WiFi connectivity for communication.
Before I proceed, I’d like to confirm a few things:
  1. Compatibility: Is the JetCore fully compatible with the Jetson Orin Nano when using multiple USB 3.0 cameras like the D435iF?
  2. USB bandwidth: Since I will connect 5 cameras, should I use a powered USB 3.0 hub? Any recommendations on managing bandwidth/power?
  3. WiFi support: Does JetCore have built-in WiFi, or should I plan to add WiFi via a USB dongle or M.2 module? If so, are there recommended modules/adapters?
  4. Power requirements: Any special considerations for powering JetCore + Orin Nano + multiple RealSense cameras together?
My main goal is to use two cameras for SLAM (front + rear) and the remaining ones for obstacle avoidance, so performance and stability are important.
Thanks in advance for the guidance!
Hi, Yes, it is fully compatible and can support D435I cameras.
Yes, USB3 hub seperately is needed and we have one in development. if you like we can help u support with it.
No, We dont offer inbuilt WIFI support. though that is something we can put in roadmap.
Currently we can support good amount of power budget lets say upto 25W easily.
congrats on your attempt for SLAM and obstacle avoidance.
Refer to following picture on how it can be done.
Are you guys using your FFC to USB C cable and I have Jetson Orin Nano module but in your website
the Fan is not available right ?
Can i be able to use jetson nano Fan ?
Please share your fan details. We will confirm the availablity.
