Hi , I am looking for Jetcore datasheet to get the interface pin specifications. Can i get a datasheet attached here as soon as possible,
Please refer to
I am finding a solution to connect a 15 pin CSI camera like raspberry pi camera t o the VECROS board . I see that there is 20 pin CSI connector along with display port upon which a daughter board will be connected.
I would like to know if we can get the daughter boards along with carrier to make 15 pin CSI cameras compatible with these carriers.
Looking forward for a solution.
Thanks for your query, Amit.
Yes, we can support you with daughter board for the same.
However, it is in development as of now.
We can extend limited access for the same.
Also is the daughter board compatible with 15 pin CSI camera like raspberry pi camera ? We would like to have the daughter board along with carrier within 5-6 days , how plausible is this ? Based on this I would like to go forward with procurement. Thanks Looking forward for a solution
We can try to provide you the board in 5–6 days. However, some of them are still under testing and might fail once you procure.
We advise to exercise caution and use USB protocols for now. Give us a 2-week time, we will get back.
