What voltage should I supply to JETCORE, either should i use 6s or 4s battery and can I use an M.2 2242 SSD?
JETCORE requires 12–18 V DC at its power input. Use a regulated supply that can support the Jetson module together with the SSD, cameras, and other connected peripherals. Check supply polarity before connecting power.
For the SSD: M.2 2242 is not supported; M.2 2280 NVMe is supported. Samsung PM9B1 NVMe is specifically listed as compatible. When ordering, check the exact drive’s form factor and select the supported 2280 size rather than relying on the PM9B1 family name alone.
The size codes describe the physical dimensions: 2242 is 22 × 42 mm and 2280 is 22 × 80 mm. The M.2 Key M connector alone does not make every drive length compatible. Use the supported NVMe drive and secure it at the proper mounting point; do not leave a shorter drive unsecured.
For a 6S battery installation, use suitable regulation before the Jetson input. A fully charged conventional 6S battery reaches 25.2 V, which is above the 18 V maximum. A power distribution board must provide the required regulated output, not simply pass battery voltage through.
The 12–18 V range also answers the 4S half of your question: a 4S pack is roughly 14.8 V nominal and 16.8 V fully charged, so it sits inside the window without extra regulation, though it is worth checking the input does not sag below 12 V under load. A 6S pack does need a regulated supply, as noted above. For storage, plan on a 2280 NVMe rather than 2242.
