Which connector do I need for Ethernet, and can I connect JETCORE directly to my PC?
Use the JETCORE-compatible 8-pin Molex PicoBlade to RJ45 Ethernet harness. Connect the 8-pin end to the board’s Ethernet connector, then use a standard Ethernet patch cable from the RJ45 socket to the PC. A PC with an Ethernet port can connect directly; no additional switch or Ethernet adapter is needed for that connection.
Use the correctly wired JETCORE harness rather than a generic 8-pin cable. Ethernet uses differential signal pairs, so matching the number of connector pins is not enough to establish cable compatibility. Seat the connector fully and avoid forcing it in the wrong orientation.
Physically that setup is fine. One thing to plan for is addressing: a direct PC-to-board link only works once both interfaces are on the same IP subnet, either by assigning static addresses or by having something provide DHCP. The cable and connector answer above is sufficient for the hardware side.
that’s an issue from jetson and jetpack though.
