Is it feasible and efficient to use Jetcore for cryptocurrency mining, considering their GPU architecture, power consumption, and thermal limitations ?
I’ve actually looked into this before — short answer: it’s not worth it.
JetCore supports Jetson modules like Orin Nano, Orin NX, Xavier NX, and even TX2 NX — all great for edge AI, robotics, and embedded systems. But for crypto mining? Not so much.
Even the higher-end ones like Xavier NX or Orin NX don’t come close to the hash rates of proper mining GPUs. You might squeeze out a few MH/s, but that’s nothing compared to even a mid-tier gaming GPU. And while the power draw is low (10–30W depending on the module), the hashrate-per-watt is just not competitive.
Also worth noting — these modules aren’t built for sustained 100% GPU load like mining demands. You’ll likely run into thermal throttling unless you rig up some serious cooling. The JetCore board itself is compact and thermally optimized for AI tasks, not continuous high-heat workloads.
So yeah, unless you’re just messing around for fun or experimentation, it’s not feasible or efficient for mining. JetCore shines way more in AI inferencing, autonomous robotics, or any project where you need performance at the edge.
