I was looking through a few of the issues linked here, and I think the USB hub cold-boot issue is particularly interesting.
From what I understand, the same USB camera works when connected after boot, and apparently also works during cold boot when connected through the physical USB3 port instead of the downstream USB2 hub. That seems like a useful clue, although I’m not sure whether it points to power sequencing, hub reset timing, or something else.
One thing that might help with these weekly testing threads is having a simple format for reporting results. Maybe something like the JetCore hardware revision, JetPack/L4T version, connected devices, whether it was a cold boot or reboot, and what actually showed up in lsusb or the relevant logs.
I imagine that would make it a lot easier to tell whether two people are seeing the same issue or just similar symptoms.
Also, I noticed the IMX477 thread mentions an FFC cable that was damaged by a short. I’d be a bit careful about asking people to repeat that particular test until the connector orientation and pinout have been confirmed.
I haven’t tested any of this hardware myself, so this is just an observation from reading the linked discussions. But I think collecting the results in a more consistent way could make these roundups much more useful over time.
