Jetson module compatibility
Can I use NVIDIA Jetson Orin NX with JETCORE?
Yes. NVIDIA Jetson Orin NX is supported in the JETCORE setup covered by these answers. Use a software image and carrier BSP that match the module, along with an appropriate heatsink and fan.
Install or remove the module only with power disconnected. Check its orientation, seating, and mounting hardware before powering the board. Make sure the cooler makes proper thermal contact and leaves room for the connected cables.
After installing the image, verify Ethernet, display output, USB, and NVMe before adding your full application. This gives you a working baseline and makes it easier to identify whether a later problem comes from a peripheral, driver, or application change.
Keep the Jetson model, JetPack version, and carrier software version with your setup notes. If you change modules, check the image compatibility again rather than assuming an image prepared for another Jetson model will behave identically.
