JETCORE Jetson heatsink fan connection: photo reference and wiring checks
This guide records the heatsink fan assembly shown in the attached photos. The installed wiring appears left to right as yellow, blue, red, black, in the side-view photo orientation.
The custom carrier header signal assignments and pin-1 orientation have not been verified. Do not use the visible wire order as a confirmed electrical pinout.
Assembly photos
Attach jetson-fan-connection.png and jetson-fan-connection.pdf from the accompanying files. The image is an AI-generated photo-based illustration; consult the original assembly photos for physical details.
Xavier NX developer kit reference only
J13 pin Signal Conventional wire colour
1 GND Black
2 +5 V Red
3 TACH, feedback to Jetson Yellow
4 PWM, control to fan Blue
This reference describes NVIDIA’s developer kit, and does not establish the pinout of the pictured JETCORE carrier. Verify the fan manufacturer’s wire assignments as well.
Connection procedure
  1. Switch off and unplug system power before changing wiring.
  2. Identify the carrier board revision and the marked four-pin header in its schematic.
  3. Confirm ground, fan supply voltage, pin-1 orientation, TACH and PWM assignments.
  4. Match the fan voltage and current requirements to the carrier’s documented supply rating.
  5. Connect with the correct keyed connector or secure insulated terminals. Keep leads clear of the fan blades.
  6. After inspection, power on and verify fan operation and temperature response.
Connector pitch, exact connector part, maximum fan current and pull-up circuitry are not established by these photos. Do not assume a 0.13 A board limit or that connector parts are interchangeable based on pitch alone.
Reference: NVIDIA Xavier NX Developer Kit Carrier Board Specification, section 3.6, table 3-6.
