JETCORE FC: Detecting Cube on Jetson over USB and forwarding MAVLink
The JETCORE system connects its Cube flight controller (FC) directly to the onboard NVIDIA Jetson through USB. The Jetson then runs a MAVProxy session that forwards the FC’s MAVLink data to a Ground Control Station (GCS) over UDP.
The architecture is straightforward:
Cube FC
   │ USB
NVIDIA Jetson
   │ MAVProxy session
   │ UDP → <GCS_IP>:<UDP_PORT>
There is one physical communication link between the Cube FC and Jetson—the USB connection—and one network output from MAVProxy to the GCS IP address and UDP port.
USB connection between the Cube FC and Jetson
When the JETCORE system is powered, the Jetson detects the Cube FC as a USB serial device. It will normally appear as:
/dev/ttyACM0
Depending on USB enumeration order, it may instead appear as /dev/ttyACM1 or another ACM device number.
Check the available device with:
ls /dev/ttyACM*
The kernel log can also confirm that Linux detected the FC:
sudo dmesg | grep -i ttyACM
Typical output looks similar to:
cdc_acm 1-2:1.0: ttyACM0: USB ACM device
To inspect the detected device in more detail, run:
udevadm info -q property -n /dev/ttyACM0
This helps confirm that the selected serial device belongs to the Cube FC.
Serial-port permission
Check the permissions on the detected device:
ls -l /dev/ttyACM0
If access is controlled by the dialout group, add the Jetson user to it:
sudo usermod -aG dialout "$USER"
Log out and log back in before starting MAVProxy again.
Starting the MAVProxy session
MAVProxy opens the Cube FC’s USB serial device and sends the MAVLink stream to the GCS through a UDP output.
Use the following command structure:
mavproxy.py \
  --master=/dev/ttyACM0 \
  --baudrate=115200 \
  --out=udp:<GCS_IP>:<UDP_PORT>
For example:
mavproxy.py \
  --baudrate=115200 \
  --out=udp:192.168.1.100:14550
Replace the example address with the IP address of the system running the GCS. The UDP port in MAVProxy and the GCS must match.
  • --master=/dev/ttyACM0 selects the Cube FC connected through USB.
  • --baudrate=115200 sets the demonstrated serial rate.
  • --out=udp:<GCS_IP>:<UDP_PORT> sends MAVLink packets to one UDP destination.
The tested setup shown in the recording used /dev/ttyACM0, 115200 baud, and a single IP-address-and-port output.
Connecting the GCS
After MAVProxy starts receiving data from the Cube FC:
  1. Confirm that the Jetson and GCS system are on the same reachable network.
  2. Start the GCS application.
  3. Select a UDP connection.
  4. Use the same UDP port configured in the MAVProxy --out argument.
  5. Wait for the MAVLink heartbeat and vehicle data.
The complete data path is:
Cube FC USB port
    → /dev/ttyACM0 on Jetson
    → MAVProxy
    → UDP packet stream
    → GCS system IP and UDP port
    → Ground Control Station
The GCS does not communicate with the Cube FC over a second USB connection. It receives the MAVLink stream sent by the MAVProxy session running on the Jetson.
Verifying the connection
When the connection is working:
  • MAVProxy reports that it has connected to the serial master.
  • MAVProxy receives a heartbeat from the Cube FC.
  • The FC firmware and vehicle information appear in the MAVProxy console.
  • The GCS receives the forwarded heartbeat through UDP.
  • The GCS displays live vehicle status and telemetry.
The supplied demonstration showed the Cube FC connected as /dev/ttyACM0, MAVProxy receiving ArduCopter data, and the GCS displaying the connected vehicle.
Troubleshooting
The Cube FC does not appear on the Jetson
Run:
ls /dev/ttyACM*
Then check:
  • The Jetson is powered and running.
  • The Cube FC is powered.
  • The USB connection between the FC and Jetson is secure.
  • The FC firmware exposes a USB serial interface.
MAVProxy cannot open the serial device
Confirm the device name and permissions:
ls -l /dev/ttyACM0
sudo lsof /dev/ttyACM0
Another application must not already own the Cube FC serial port.
MAVProxy connects, but the GCS receives nothing
Check the following:
  • The --out address is the GCS system’s IP address.
  • The UDP port matches the port opened by the GCS.
  • The Jetson can reach the GCS system over the network.
  • A firewall is not blocking the selected UDP port.
  • MAVProxy is receiving a heartbeat from the Cube FC.
You can test basic network reachability from the Jetson with:
ping <GCS_IP>
Device-name stability
The Cube FC may not always enumerate as /dev/ttyACM0. For a permanent installation, create a udev rule that gives it a stable name such as /dev/jetcore-fc.
MAVProxy can then use the stable device:
mavproxy.py \
  --master=/dev/jetcore-fc \
  --baudrate=115200 \
Summary
The JETCORE FC communication architecture consists of three parts:
  1. The Cube FC communicates with the Jetson through USB.
  2. MAVProxy on the Jetson reads MAVLink from the Cube FC.
  3. MAVProxy forwards the MAVLink stream to the GCS system’s IP address on one UDP port.
Cube FC ──USB──> Jetson/MAVProxy ──UDP──> GCS
Once the correct USB device, GCS IP address, and UDP port are configured, the GCS can receive the Cube FC heartbeat and telemetry through the Jetson.
If the ACM number changes between boots, pin the Cube to a stable device path with a udev rule instead of relying on /dev/ttyACM0. Use udevadm info -a -n /dev/ttyACM0 to find a stable attribute such as the USB serial number, then create a rule that adds a symlink like /dev/cube_fc. MAVProxy can then use --master=/dev/cube_fc without editing the command after enumeration changes.
